Too many loops plus crown in a narrow wall
Beefeater
Post by Beefeater »
I did not make a separate example, but we can see the problem in the attached model near X1.407 Y29.416 Z4.767. Part of the cross-section is too narrow for two loops, but KS makes two loops anyway, which is already an over-extrusion.Then on top of that, it puts a crown bead there, too. Altogether, the wall gets about twice the amount of material it should. Happens in both KS 1.6.3 and 2.0.4.4.
Overextrusion.zip
(456.26 KiB) Downloaded 253 times
Re: Too many loops plus crown in a narrow wall
I have reported a crown path problem with multiple filaments which is being worked on.
This is now also reported.
