I'm sorry, I can't seem to duplicate the issue. With the settings you showed earlier wipe is working for me. When I set under [Matl] Wipe=5, Min Jump=0, and Trigger=0 (and of course first I forgot to map my test material in the [Ext Map] tab [8^), then under [Style] I had De-String and Wipe both checked, I get a wipe after every single extrusion. (Both the ugly yellow line in the path preview window, and the actual motion commands in the G-code.)
Could you please email me a zip of the full output G-code from RC2 (preferably on a small part that still shows the issue) along with the 4 INI files and the test STL?
I'll try to find time to send some code ASAP. Thanks for your efforts, Jonathan. I'm in the middle of a very difficult home sale and family move and my time for 3D printing is very limited. I might have time to try your settings this weekend, however.
I'm getting the wipe now. I'll try to find time to duplicate what I did previously. I'm pretty sure I had the destring boxes checked.
Thanks for looking into it, Jonathan, and I'm sorry that I don't have more time to do more than confirm it's now working with min. jump and trigger both set to zero and also 1 mm and 5 mm respectively.
Edit: Yes the boxes were checked. Looking at the code snipped from my previous post on this thread I had
