No Support inside the Object
Posted: 21 Feb 2020, 12:12
by droidbox
Hello forum.
What do I have to set so that I have the support only outside the object and not inside?
Regards Droidbox
Re: No Support inside the Object
Posted: 23 Feb 2020, 08:09
by ksh_germany
At the Moment there is no settings for that you can try Set Support angle higher or/and rotate object to minimalize Support needing
Posted: 24 Feb 2020, 03:34
Depending on the model, "Support Z Roof" may also help.
Posted: 24 Feb 2020, 07:21
by droidbox
Thanks a lot for the infos.
I will check the "Support Z Roof" option
droidbox
