Can't figure out PreloadVE tuning wizard
Dorje
Post by Dorje »
I'm hoping you can help me make sense of PreloadVE tuning.
Ages ago, when I first started playing with Kisslicer - this worked for me just fine. I did loads of tuning, could see the differences around seams on my printouts.
Now, I am trying to configure a new printer and tune it, but I can't figure out what I'm doing wrong. The seam looks the same from top to bottom regardless of whether I set the parameter between 0 and 0.1 or 0 and 10.
The printer is a direct extruder, with drv len at 80mm, a 1.75mm nozzle.
Filaments are mostly ABS (although I get the same with PLA). Temps are around 255C on the hotend.
Kisslicer version is 2.0.6 Win64.
My settings look like below.
I know I'm missing something obvious, but can't figure out what.
Any hints would be much appreciated.
ksh_germany
Re: Can't figure out PreloadVE tuning wizard
Post by ksh_germany »
PreloadVE Coefficient [microseconds]
(0 - 2x Experimental Wizard value) this value you need first. you get it by clicking "init" besides PreloadVE field.
i choose the experimintally version, otherwise you need some values from filament manufactor
Dorje
Post by Dorje »
Thanks for the response.
As it turned out, I totally missed that nozzle diameter was just... totally wrong ;)
Now it works.
