Does anyone have the settings for:
Materials
Printers
Styles
Supports
I had them from the Kisslicer forum awhile ago, but now have a new computer and forgot to transfer them over.
Thanks!
3D Touch Settings
Re: 3D Touch Settings
Hi, yeah, I have the settings, but they have been heavily tweaked and I don't know if they will work for you. I was searching for the original settings too to compare what I have actually changed a while back. I have also started to save some material settings..perhaps you should delete those and keep the default values. Give it a try.
- settings.zip
- (2.5 KiB) Downloaded 1011 times
How do I have to install the ini files
+1 to this request; I've a 'defunct' BFB3000 that I'm trying to get working again and I think I'm struggling with an Axon2 issue. Any advice on using these .ini settings?
Cheers,
OLC
Cheers,
OLC
In the folder that contains the KISS executable, you will find 4 _*.ini files with the same names as those uploaded.
As a quick test, you can rename your existing ini files and simply drop those from the uploaded zip in their place.
You can also open each of the ini files in turn with a text editor and copy/paste the relevant sections to your existing ini files, but you have to ensure that the section name (in square brackets) is not duplicated elsewhere in the file.
I notice that the _printers.ini file does not define printers, but actually the type of print required:
[Default ABS with PLA pillar raft]
[Default PLA with ABS raft]
etc.
I've been using kisslicer for quite some time.
i own the printer BFB 3D Touch Single.
actually, the software works well.
but somehow I find the printer results at PLA with
the software Axon 2.0 nevertheless better. Has anyone exactly this
settings for Kisslicer?
would be nice.
(German translation with goole translator)
would be nice.
- Sample Axon 2.zip
- (28.64 KiB) Downloaded 507 times
