No Support inside the Object
droidbox
Post by droidbox »
Hello forum.
What do I have to set so that I have the support only outside the object and not inside?
Regards Droidbox
ksh_germany
Re: No Support inside the Object
Post by ksh_germany »
At the Moment there is no settings for that you can try Set Support angle higher or/and rotate object to minimalize Support needing
Depending on the model, "Support Z Roof" may also help.
droidbox
Post by droidbox »
Thanks a lot for the infos.
I will check the "Support Z Roof" option
droidbox
